ShadowStorm
Dec 27, 2017Aspirant
Factory Reset RN102
Started having problems with the RN102 Nas and it not being detected ofter installing the OS6, thought that the OS might be corrupted or did not install propperly so tried to reinstall the OS with th...
- Dec 29, 2017
If you aren't seeing it RAIDar (when diskless), that does suggest a hardware failure.
Have you checked your warranty status? The warranty is 3 years for the original purchaser.
ShadowStorm
Dec 29, 2017Aspirant
Just tried that and its not showing up on RAIDar nor on the local network, at the moment after starting it up the Power Light and Disk1&2 alternating.
Dec 29, 2017Guru - Experienced User
- ShadowStormDec 29, 2017Aspirant
Well if its a hardware failure theres really not much I can do about it.
Although its funny that this happend 1 month after the warrenty expires.
- StephenBDec 30, 2017Guru - Experienced User
Are you seeing any status LEDs on the ethernet ports (both the NAS and the router/switch ends). It's probably worth trying a different cable, and perhaps a different port in the router/switch.
- ShadowStormDec 30, 2017Aspirant
Yes there is an LED status on the port diffrent cable and switch where used still nothing.
