richardh1
Nov 18, 2014Aspirant
Factory reset with no reset button #24223141
I'm trying to perform a factory reset on my SPARC NV+ but the reset button is physically damaged - any idea how to do the reset without being able to push the button? thanks…
Nov 18, 2014Guru - Experienced User
The advice is to unformat them - either by deleting all partitions or by zeroing enough sectors so that the partition tables are erased.
richardh wrote: Regrettably, it's kernel panicing before it launches frontview. I do have a forensic dock so, if I understand you correctly, formatting the disks in that will tell the system that the drives are new and therefore to do a factory-fresh install?
But overall, yes - the NAS will do a factory install if the disks look "new". The OS is stored on the disks, so the kernel panic can't occur.
