meshedlibrarian
Nov 17, 2017Aspirant
Firmware 6.9.0 update error
After upgrading to Fireware 6.9.0 from 6.8.0, we are encountering an error about one of our network connections (eth1) in teaming mode being offline. Screenshot attached. ~meshed
meshedlibrarian
As a follow-up, I pulled eth0 and lost network connection. Teaming mode / bond seems to have been broken with this update.
~meshed
Nov 18, 2017Guru - Experienced User
There was a hot-fix pushed for 6.9.0 systems, so you could try rebooting the NAS to make sure you have it installed. This post gives some info on how to tell if the hot fix (6.9.0+4) is installed: https://community.netgear.com/t5/Using-your-ReadyNAS/backups-from-pc-failing-after-upgrade/m-p/1410863/highlight/true#M138209
You could also try 6.9.1 beta.
