e__e
Sep 14, 2015Aspirant
Firmware update and ReadyNAS File Systems
I would like to know which File Systems in the ReadyNAS OS are not impacted by a firmware update. Probably /data /media /home /apps But is /root also not overwritten by a firmware upda...
e__e
Thanks.
So it is indeed very unlikely there is a file name collision in /root...
mdgm-ntgr
Sep 14, 2015NETGEAR Employee Retired
Still with custom scripts it is possible that depending on how it is done you may encounter unpredictable behaviour. So best to make sure your backup is up to date before doing a firmware update.
