RNASguy
Aug 22, 2012Luminary
Firmware upgrade fail #19255699
Had a fail when I attempted to update firmware from 4.1.8 to 4.1.9 as follows: Issue with Firmware update for: ReadyNAS Duo serial # 24M3037701D1A This chassis was replaced on March 21, 2012 unde...
RNASguy
OOM-9 wrote: It looks like they are wanting you to boot the unit into tech support mode.
Once you have the unit into tech support mode, please up the date the case with the 5 digit number that it shows in Telnet mode.
OK, but why don't I see that in the case file. I can open an old case file and see all comms back and forth , but for this one I only see my OP, and a new post I just did saying I don't see
any reply from support.
Where are you seeing what you report above??
bc
PS: Also, I just tried booting it again and there is a slight change. The power light is now steady, and the two drive lights blink slow (together) On-Off. AND, how does one telnet to a device that is not ping-able on my network, and is not seen by RAIDar.
