RNASguy
Aug 22, 2012Luminary
Firmware upgrade fail #19255699
Had a fail when I attempted to update firmware from 4.1.8 to 4.1.9 as follows: Issue with Firmware update for: ReadyNAS Duo serial # 24M3037701D1A This chassis was replaced on March 21, 2012 unde...
mdgm-ntgr
Aug 22, 2012NETGEAR Employee Retired
When did you purchase the Duo?
Try to get it into tech support mode. It should show in RAIDar when in this mode and will dynamically receive an I.P. address from your router. Forward port 23 to the NAS and put your WAN (internet) I.P. address in your case.
If it doesn't boot into tech support mode, try powering down, removing the disks and attempting to boot into tech support mode without disks installed.
Do not use TFTP boot recovery as this is very unreliable. If anything do a USB Boot Recovery, but this should only be attempted if booting into tech support mode doesn't work.
