RNASguy
Aug 22, 2012Luminary
Firmware upgrade fail #19255699
Had a fail when I attempted to update firmware from 4.1.8 to 4.1.9 as follows: Issue with Firmware update for: ReadyNAS Duo serial # 24M3037701D1A This chassis was replaced on March 21, 2012 unde...
mdgm-ntgr
Aug 23, 2012NETGEAR Employee Retired
If you select the telnet option in PuTTy and enter the correct I.P. address (you'd use the LAN I.P. of the NAS when on the same LAN as the NAS) you should get a login prompt. Seeing you don't it doesn't look like tech support mode is working on your system.
