RNASguy
Aug 22, 2012Luminary
Firmware upgrade fail #19255699
Had a fail when I attempted to update firmware from 4.1.8 to 4.1.9 as follows: Issue with Firmware update for: ReadyNAS Duo serial # 24M3037701D1A This chassis was replaced on March 21, 2012 unde...
RNASguy
Aug 23, 2012Luminary
Yes, using Putty in telnet mode I used the new ip that appeared in the router. Putty opens a new command prompt like window but there is nothing in it except the green cursor block.
