RNASguy
Aug 22, 2012Luminary
Firmware upgrade fail #19255699
Had a fail when I attempted to update firmware from 4.1.8 to 4.1.9 as follows: Issue with Firmware update for: ReadyNAS Duo serial # 24M3037701D1A This chassis was replaced on March 21, 2012 unde...
RNASguy
Aug 26, 2012Luminary
Well, here's an update on the update:
I got brave, and since it seemed that I could boot the box off USB if it failed, I did a normal shut down. I did a boot up and ... guess what... it came up normal.
So... what is really going on here... If it was bad flash, why does it boot normal, now, with out the USB drive. I still won't try a 4.1.9 update.... don't trust it.
bc
bc
