RNASguy
Aug 22, 2012Luminary
Firmware upgrade fail #19255699
Had a fail when I attempted to update firmware from 4.1.8 to 4.1.9 as follows: Issue with Firmware update for: ReadyNAS Duo serial # 24M3037701D1A This chassis was replaced on March 21, 2012 unde...
RNASguy
Aug 26, 2012Luminary
re: mem test. When these boxes were installed I upgraded to 1GB on both. At that time I ran the memtest about 10 times on each box. I have not done that since this update issue. But, thanks for the suggestion. Does that also test the flash chip, or as I thought just test the RAM memory. I'll run it a few times in any case and report back if it shows any issue.
bc
bc
