JanHussaarts2
Aug 07, 2017Luminary
Frontview not avaialble after installing git
Hi,
I am on os 6.7.5
I tried installing git is terminal mode via apt-get install git-all.
After that frontview is no longer available.
Start or restart apache fails:
root@HITc_NAS:/frontview/dashboard# systemctl status apache2.service
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─forking.conf
Active: failed (Result: exit-code) since Mon 2017-08-07 21:02:58 CEST; 4min 26s ago
Process: 8445 ExecStart=/usr/sbin/apache2 $OPTIONS -k start (code=exited, status=1/FAILURE)
Process: 8299 ExecStartPre=/frontview/bin/fvapps (code=exited, status=0/SUCCESS)
Aug 07 21:02:57 HITc_NAS fvapps[8299]: WARNING: Excluding bad https config for app 'mysqlr6'
Aug 07 21:02:57 HITc_NAS fvapps[8299]: WARNING: Excluding bad https config for app 'nzbget-rn'
Aug 07 21:02:57 HITc_NAS fvapps[8299]: WARNING: Excluding bad https config for app 'phpmyadminr6'
Aug 07 21:02:57 HITc_NAS fvapps[8299]: WARNING: Excluding bad https config for app 'phpr6'
Aug 07 21:02:58 HITc_NAS apache2[8445]: apache2: Syntax error on line 140 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-
enabled/auth_token.load: Cannot load /usr/lib/apache2/modules/mod_auth_token.so into server: /usr/lib/apache2/modules/mod_auth_token.so: cannot open
shared object file: No such file or directory
Aug 07 21:02:58 HITc_NAS systemd[1]: apache2.service: Control process exited, code=exited status=1
Aug 07 21:02:58 HITc_NAS systemd[1]: Failed to start The Apache HTTP Server.
Aug 07 21:02:58 HITc_NAS systemd[1]: apache2.service: Unit entered failed state.
Aug 07 21:02:58 HITc_NAS systemd[1]: apache2.service: Triggering OnFailure= dependencies.
Aug 07 21:02:58 HITc_NAS systemd[1]: apache2.service: Failed with result 'exit-code'.
The shares are still working. It is just the stuf that depend on apache that is failing.
Is there an easy way to get it working? Can I reinstall 6.7.5 in terminal mode?
I could not solve the issues and deciced to do a factory reset.
- JanHussaarts2Luminary
I decided to remove apache2 completely and reinstall via the boot menu.
That did not solve te problems. However I was able to install 3.8.0 RC1 using fwbroker.
Several other problems are now occurring, but I can get to the admin page.
