1_0_1
Oct 04, 2014Aspirant
Frontview webpage loading partial
I am unable to log onto my old ReadyNAS Pro 4 anymore after doing a factory reset. I can configure the unit via RAIDar but once I want to login to the web interface it gives a partial loaded page. It ...
Oct 04, 2014Guru - Experienced User
New feature development has stopped, but warranty is not affected by that. Support should be able to fix your issue - I suspect that they can do it remotely, which wouldn't require an RMA - but am not sure how they'd handle it.
