1_0_1
Oct 04, 2014Aspirant
Frontview webpage loading partial
I am unable to log onto my old ReadyNAS Pro 4 anymore after doing a factory reset. I can configure the unit via RAIDar but once I want to login to the web interface it gives a partial loaded page. It ...
Oct 04, 2014Guru - Experienced User
If that is the case, then the factory reset on the new disk will fail - that is why I suggested trying that.
USB recovery is a last resort - and has risks which could make things worse. So you shouldn't try that unless someone like mdgm or chirpa recommend it.
