1_0_1
Oct 04, 2014Aspirant
Frontview webpage loading partial
I am unable to log onto my old ReadyNAS Pro 4 anymore after doing a factory reset. I can configure the unit via RAIDar but once I want to login to the web interface it gives a partial loaded page. It ...
1_0_1
While I am waiting should I try another set of factory resets?
1. Factory reset unit and restart unit. Then erase disks with RAIDar instead of creating the volume
2. Re-install OS
Or is there any other sequence I should follow as I have done this so many times now already? Furthermore I have 4x 3TB drives which takes long with disk operations like erase. Can I also just use one disk for the troubleshooting and later add the other disks once this all is hopefully working?
2. Re-install OS
