steveoelliott
Apr 26, 2013Luminary
FSCK Found Errors on Boot
Hi all, Just rebooted my NAS today after 200 days uptime and thought I'd request a volume scan and it found errors! I've never had a power outage etc so am keen to know what could have caused this ...
steveoelliott
May 08, 2013Luminary
Well... I have some new and interesting information.
After deleting the file, and re-creating from backup, the file system got mounted read only and the following errors were logged:]
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904376:freeing already freed block (bit 1144)
May 8 14:58:15 despair kernel: Aborting journal on device dm-0-8.
May 8 14:58:15 despair kernel: EXT4-fs (dm-0): Remounting filesystem read-only
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904377:freeing already freed block (bit 1145)
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904378:freeing already freed block (bit 1146)
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904379:freeing already freed block (bit 1147)
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904380:freeing already freed block (bit 1148)
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904381:freeing already freed block (bit 1149)
May 8 14:58:15 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904382:freeing already freed block (bit 1150)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904383:freeing already freed block (bit 1151)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904384:freeing already freed block (bit 1152)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904385:freeing already freed block (bit 1153)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5124block 167904386:freeing already freed block (bit 1154)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949296:freeing already freed block (bit 13296)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949297:freeing already freed block (bit 13297)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949298:freeing already freed block (bit 13298)
May 8 14:58:16 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949299:freeing already freed block (bit 13299)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949300:freeing already freed block (bit 13300)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949301:freeing already freed block (bit 13301)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949302:freeing already freed block (bit 13302)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949303:freeing already freed block (bit 13303)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949304:freeing already freed block (bit 13304)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949305:freeing already freed block (bit 13305)
May 8 14:58:17 despair kernel: EXT4-fs error (device dm-0): mb_free_blocks:1411: group 5125block 167949306:freeing already freed block (bit 13306)
These are the same blocks slated as multiply claimed
And then running an FSCK, we got the following:
***** File system check forced at Wed May 8 15:16:50 WEST 2013 ***** fsck 1.41.14 (22-Dec-2010) e2fsck 1.42.3 (14-May-2012)
/dev/c/c: recovering journal
Pass 1: Checking inodes, blocks, and sizes Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information Free blocks count wrong for group #5124 (28170, counted=28159).
Fix? yes
Free blocks count wrong for group #5125 (25861, counted=25850).
Fix? yes
Free blocks count wrong (420683133, counted=420644972).
Fix? yes
Free inodes count wrong (29595347, counted=29595271).
Fix? yes
/dev/c/c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/c/c: 616825/30212096 files (13.6% non-contiguous), 62748564/483393536 blocks
Volume seems clean now after reboot and keeps coming back clean.
Any ideas based on this? The old Database was over 1.6 GB in size. The re-created one from backup is much smaller 33MB (as it was compacted before restoring). Once these DB files grow they don't get smaller until compacted. Although I'm sure file size should not have a bearing on this.
Many Thanks
Stephen Elliott
Fix? yes
Fix? yes
Fix? yes
Fix? yes
Many Thanks
Stephen Elliott
