StanKaminski
Dec 05, 2011Aspirant
FTP connection to a ReadtNAS Ultra
I am having a problem setting up a FTP connection to my ReADYnas uLTRA 4 THRU MY vERIZON fios rOUTER. iT SEEMS TO ESTABLISH A CONNECTION BUT TIMES OUT WHEN REQUESTIONG A DIRESTORY LIST. iF i AM INSIDE...
Dec 05, 2011Guru - Experienced User
What FTP client are you using?
StanKaminski wrote: I am having a problem setting up a FTP connection to my ReADYnas uLTRA 4 THRU MY vERIZON fios rOUTER. iT SEEMS TO ESTABLISH A CONNECTION BUT TIMES OUT WHEN REQUESTIONG A DIRESTORY LIST. iF i AM INSIDE MY ROUTER THE FTP CLIENT WORKS. iI CHECKED AND THE PORTS I AM USING ARE OPENED. I AM OUT OF IDEAS. HELP!
Note that with passive FTP ports, the masquerading can be set up for either inside the router or outside the router, but not both. However, if you set up the NAS for inside-the-router (the default),the FileZilla client will work properly outside-the-router as well- it detects and works around the issue.
