StanKaminski
Dec 05, 2011Aspirant
FTP connection to a ReadtNAS Ultra
I am having a problem setting up a FTP connection to my ReADYnas uLTRA 4 THRU MY vERIZON fios rOUTER. iT SEEMS TO ESTABLISH A CONNECTION BUT TIMES OUT WHEN REQUESTIONG A DIRESTORY LIST. iF i AM INSIDE...
Dec 06, 2011Guru - Experienced User
StanKaminski wrote: All ports in the router are forwarded to the NAS.
I confirmed that the ports are open.
It does work correctly inside the firewall.
I think the problem is that your internal IP address looks routeable to FileZilla (173.xxx.xxx.xxx)
This is what I see(ftp over tls)...
Status: Resolving address of blah.blah.blah
Status: Connecting to xxx.xxx.xxx.xxx:xxxxx...
Status: Connection established, waiting for welcome message...
Response: 220 ProFTPD 1.3.3c Server (NETGEAR ReadyNAS) [192.168.1.16]
Command: AUTH TLS
Response: 234 AUTH TLS successful
Status: Initializing TLS...
Status: Verifying certificate...
Command: USER admin
Status: TLS/SSL connection established.
Response: 331 Password required for admin
Command: PASS ********
Response: 230 User admin logged in
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Features:
Response: MDTM
Response: MFMT
Response: TVFS
Response: UTF8
Response: AUTH TLS
Response: MFF modify;UNIX.group;UNIX.mode;
Response: MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
Response: LANG en-US*
Response: PBSZ
Response: PROT
Response: SITE MKDIR
Response: SITE RMDIR
Response: SITE UTIME
Response: SITE SYMLINK
Response: REST STREAM
Response: SIZE
Response: 211 End
Command: OPTS UTF8 ON
Response: 200 UTF8 set to on
Command: PBSZ 0
Response: 200 PBSZ 0 successful
Command: PROT P
Response: 200 Protection set to Private
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/" is the current directory
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (192,168,1,16,xx,xx).
Status: Server sent passive reply with unroutable address. Using server address instead.
Command: MLSD
Response: 150 Opening ASCII mode data connection for MLSD
Response: 226 Transfer complete
Status: Directory listing successful
