Slasky
Jul 03, 2012Aspirant
FTP server using passive ports
Hello everybody.
This is more of a network-question than a readynas one.
I've just recently bought an Ultra 4 in an addition to my Duo. I've had, and still have the FTP service running at the Duo, and was setting up the same for the Ultra.
Problem one was that my router can't seem to forward the same port to two different devices, but thats not the issue.
I chose another port for the FTP server on the Ultra, and forwarded that port in my router to the Ultra's IP address. The problem is that the Ultras FTP server uses the passive ports, since the server sends a passive response. I'd think that since I've opened the port in question, the server would go in active mode, but after further examination, I see during logging onto both the servers, both enters passive mode.
The weird part is this:
When I log onto the FTP server on the Duo, I don't have to open the passive ports in the router, and it seems to use the FTP port I've specified.
When I log into the FTP server on the Ultra, I can't seem to fully enter without defining the passive ports in the router.
As I said, I've forwarded the specified port in the router for the Ultra server, but it won't use it -.-
Any suggestions?
Greetings, Slasky
Any suggestions?
Greetings, Slasky
- SlaskyAspirantAaaaand of course.. the FTP server won't allow passive ports under 1024 -.-
Guess its the trade-off then - StephenBGuru - Experienced UserThere is no harm in trying active mode with filezilla from work. If the firewall acts as a proxy, it might allow it. Though pugilares is likely correct.
BTW another option (though sluggish) is to try ReadyNAS Remote. - SlaskyAspirantI'm not that desperate :P The corp firewall blocked the connection attempt, so no avail there. I'll just RDP and change the port forwarding if needed.
Thanks for the idea bouncing and ideas! :D
