pasan
Feb 20, 2017Aspirant
FTP user authenticated access issues - Error code 15002040001
I have enabled FTP access on 2 of my file shares with access permissions Everyone, admin +RW. My understanding is this will allow only authenticated users to access the shares via FTP. How...
- Mar 02, 2017
Checked the logs, the only clue found is the error log "cannot enable dlna when no volume exists", I am thinking if there are some settings about ReadyDLNA block the operation. Can you try disable ReadyDLNA firstly ? Then try to edit FTP settings.
FramerV
Feb 21, 2017NETGEAR Employee Retired
Hi pasan,
Welcome to the community.
For now, kindly send in your system logs then reply back here if you have done it so that I can request for our subject matter expert to take a look at it.
How do I send all logs to ReadyNAS Community moderators?
pasan
Feb 22, 2017Aspirant
Hi FramerV,
I have emailed my system logs as per the linked instructions.
Hope the subject matter expert can explain the cause of this issue and a solution that won't involve resetting the ReadyNAS and deleting all data on it.
Thanks.
- FramerVFeb 24, 2017NETGEAR Employee Retired
Hi pasan,
Let me have it checked.
- pasanFeb 28, 2017Aspirant
Hi FramerV, any updates after checking my logs?
- Ki_Adi_MundiMar 02, 2017NETGEAR Employee Retired
