Oz2014
Feb 16, 2014Aspirant
Hard drive says it is full
HI all, I have a ReadyNas Duo with two green hard drives of 2 terabytes each. It is telling me that 99% of the drive is full (~1900 gigs used) but when I add up all three partitions it only comes to ...
vandermerwe
Feb 18, 2014Master
Home shares would be created for each user created on the NAS.
They are setup so that that user has exclusive access to that share.
You should be able to see the contents of it if you log in with each user's credential, at:
ipaddressofnas/shares
You may need to create windows logins to match the NAS user details.
Another way to look is to enable ssh and look at the directories and their sizes. You need to be comfortable doing this though.
