Callesoroe
Oct 30, 2013Aspirant
Haveged on ReadyNas Ultra ?
I am running LMS (squeezebox) on my readynas ultra. There is a problem with the Random mix. The problem is that it isn't very random. The problem could be this that I have read about: http://www.i...
fastfwd
Oct 30, 2013Virtuoso
Callesoroe wrote: I am running LMS (squeezebox) on my readynas ultra. There is a problem with the Random mix. The problem is that it isn't very random.
http://www.issihosts.com/haveged/
I thought that that was unlikely, and I was about to post a response saying so... But then I checked my Pro Pioneer's available entropy and discovered that it was REALLY low -- single digits or low double digits -- and I took those measurements while I was logged in and right after I'd performed some filesystem commands that should have produced a large increase in available entropy.
Maybe there's something on my system that is voraciously consuming entropy; I'll have to investigate further. But I guess it is possible that an additional entropy source like havege could be helpful.
