golfo1234's avatar
golfo1234
Follower
Jan 25, 2016
HELP my readynas duo its NO FIRMWARE INSIDE
PLEASE i need help for install a firmware by usb front.
i lost the firmware. the reayd nas is blow all ligths when starts
raidar dont connect.
the reset in back side dont fix a problem
i need install a last firmware.
anyboddy can help me???
thanks
    • BrianL2's avatar
      BrianL2
      NETGEAR Employee Retired
      Hi golfo1234,
      Welcome to the community!
      In addition to StephenBs suggestion, you can also do a direct connect procedure to check if the ReadyNAS hardware is still okay.
      Kind regards,
      BrianL
      NETGEAR Community Team
      • StephenB's avatar
        The first step (removing disks, and powering up) is intended to let you know if the NAS hardware (and flash) are ok  - or if the problem is related to the disks.
        Brian's suggestion needs to be done with the disks inserted, and should be a second step.  It is intended to rule out a problem on your network.
        Once we know both outcomes and the model information, we'll have a better idea on the next steps.
        Do you have a backup of your NAS?
ProSupport for Business
