Syxx6
Sep 22, 2016Aspirant
[HELP] ReadyNAS Duo v2 - Cannot Raid 0, keeps doing Raid 1
Hi there, I am having an issue with my newly used (bought it awhile ago just now using it) ReadyNAS Duo v2. I recently picked up 2x WD 2TB drives and I'm trying to set up my drive so that I can have...
Sep 22, 2016Guru - Experienced User
Will two RAID-0 volumes work for you? That is much safer anyway, since one volume totally fails when either disk fails.
If so, do the reset/flex-raid->RAID-0 procedure with only one drive installed. Then hot-insert the second drive and create a new volume.
