Syxx6
Sep 22, 2016Aspirant
[HELP] ReadyNAS Duo v2 - Cannot Raid 0, keeps doing Raid 1
Hi there, I am having an issue with my newly used (bought it awhile ago just now using it) ReadyNAS Duo v2. I recently picked up 2x WD 2TB drives and I'm trying to set up my drive so that I can have...
Sep 22, 2016Guru - Experienced User
Will two RAID-0 volumes work for you? That is much safer anyway, since one volume totally fails when either disk fails.
If so, do the reset/flex-raid->RAID-0 procedure with only one drive installed. Then hot-insert the second drive and create a new volume.
mdgm-ntgr
Sep 22, 2016NETGEAR Employee Retired
Also RAIDar 4.3.8 shouod work for setting the RAID level. The problem using RAIDar 6.x for this is a known issue. RAIDar 6 was designed primarily with our current models in mind.
