devs1
Apr 08, 2012Aspirant
Help trying to restore from usb backup (error code -50).
Hi, I'm desperately trying to restore from a USB backup and receive the following error message " The operation can’t be completed because an unexpected error occurred (error code -50)." when trying t...
devs1
Apr 09, 2012Aspirant
Update.
I seem to have found a way to copy the files over via terminal. Using the cp command (detailed here:http://support.apple.com/kb/TA20831)
The files are still being copied and will be for a while so I'm yet to check if any problem files are being skipped or not?
Could anyone with knowledge of the Nas let me know if I should repair the permissions via the Nas when I get the files back? If so how is this done?
Thanks.
Thanks.
