avsathish
Aug 24, 2016Follower
How do I backup my datas from local remote system to NAS?
I am trying to backup my local system datas to NAS box but did not. Here are my backup job settings.
Source:
Type: remote
Name: remote: Windows/NAS (Timestamp)
Host: <local ip-192.168.1.1>
path: <local system sharing drive - D>
login: <local system username>
password: <local system password>
Destination:
type: share
host:
path:
login:
password:
schedule:
enable schedule: enabled
backup every: 24 hours
time: 00.05 to 23.05
But I can not backup files. It shows backup error message.
I am a new customer/user of Netgear ReadyNAS box. So can you someone answer my error.
1 Reply
192.168.1.1 sounds like your router's IP address, not the PC. Are you certain this is the correct IP address?
Also, if you have a second PC you might want to see if you can access the shared D drive from there (using the same credentials).
If not, you could use a mobile app to test access to the D drive - for example goodreader for IoS, or solid file explorer for Android.
