Gilfammedicine
Feb 13, 2019Aspirant
How do i do a Speed Test?
My ReadyNas 212 is running extremely slow. Last time i just did the update and it solved the problem. But this time there is no update. My Antivirus is off and it has been working very fast recently....
- Feb 14, 2019
If you have a Windows PC, I suggest using NAStester ( http://www.808.dk/?code-csharp-nas-performance )
Feb 14, 2019Guru - Experienced User
Gilfammedicine
Feb 18, 2019Aspirant
These were my speed test results. It seems like an average pf 72 mb/sec is a pretty good speed and yet our system runs so slowly. As an example, it took about 10 minutes to open a small PDF.
Running warmup...
Running a 400MB file write on O: 5 times...
Iteration 1: 10.90 MB/sec
Iteration 2: 94.06 MB/sec
Iteration 3: 102.16 MB/sec
Iteration 4: 82.46 MB/sec
Iteration 5: 71.32 MB/sec
Average (W): 72.18 MB/sec
Running a 400MB file read on O: 5 times...
Iteration 1: 85.41 MB/sec
Iteration 2: 30.46 MB/sec
Iteration 3: 89.10 MB/sec
Iteration 4: 78.16 MB/sec
Iteration 5: 85.75 MB/sec
Average (R): 73.77 MB/sec
- GilfammedicineFeb 18, 2019Aspirant
After restart, speed seemed to increase, but it will start to slow down again to a crawl. These are the speed test results after restart.
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Iteration 1: 94.57 MB/sec
Iteration 2: 96.99 MB/sec
Iteration 3: 102.03 MB/sec
Iteration 4: 42.81 MB/sec
Iteration 5: 62.01 MB/sec
Average (W): 79.68 MB/sec
Iteration 1: 95.40 MB/sec
Iteration 2: 74.28 MB/sec
Iteration 3: 83.89 MB/sec
Iteration 4: 94.65 MB/sec
Iteration 5: 42.09 MB/sec
Average (R): 78.06 MB/sec
----------------------------- - StephenBFeb 18, 2019Guru - Experienced User
You should be getting speeds in the 100 MB/s range - and you are sometimes, but then you see the big drops (for example the 10 MB/sec test above). Was anyone else accessing the NAS when you ran the speed test?
Also,
What firmware are you running?
What apps/services do you have installed?
- GilfammedicineFeb 19, 2019Aspirant
Gotcha. No one else was on at the time. Currently, my computer is the only one mapped to the NAS while i am figuring out all the quirks.
I don't have any apps and my firmware is up to date. I took a screen shot of the admin panel.
- StephenBFeb 19, 2019Guru - Experienced User
Perhaps download the log zip file, and look at the SMART stats in disk_info.log
