Gilfammedicine
Feb 13, 2019Aspirant
How do i do a Speed Test?
My ReadyNas 212 is running extremely slow. Last time i just did the update and it solved the problem. But this time there is no update. My Antivirus is off and it has been working very fast recently....
- Feb 14, 2019
If you have a Windows PC, I suggest using NAStester ( http://www.808.dk/?code-csharp-nas-performance )
Gilfammedicine
Feb 19, 2019Aspirant
Gotcha. No one else was on at the time. Currently, my computer is the only one mapped to the NAS while i am figuring out all the quirks.
I don't have any apps and my firmware is up to date. I took a screen shot of the admin panel.
Feb 19, 2019Guru - Experienced User
Perhaps download the log zip file, and look at the SMART stats in disk_info.log
- GilfammedicineFeb 19, 2019Aspirant
Where do i find that file?
- StephenBFeb 19, 2019Guru - Experienced User
Go into the web ui, and download the log zip (the download logs control is on the logs tab).
Also, I'd look for network errors in network_settings.log.
You could also look for errors in system.log and kernel.log (around the time of the glacial pdf transfer).
I don't see any erros in those logs. The readycloud.log had hundreds of errors, but not sure if that is linked to the slowness? I don't need access to the cloud as much as i need my local network to be functional and fast. Thank you so much for taking the time to help me out, i'm a little bit of a noob when it comes to the NAS.
