Gilfammedicine
Feb 13, 2019Aspirant
How do i do a Speed Test?
My ReadyNas 212 is running extremely slow. Last time i just did the update and it solved the problem. But this time there is no update. My Antivirus is off and it has been working very fast recently....
- Feb 14, 2019
If you have a Windows PC, I suggest using NAStester ( http://www.808.dk/?code-csharp-nas-performance )
Feb 19, 2019Guru - Experienced User
Go into the web ui, and download the log zip (the download logs control is on the logs tab).
Also, I'd look for network errors in network_settings.log.
You could also look for errors in system.log and kernel.log (around the time of the glacial pdf transfer).
Gilfammedicine
Feb 19, 2019Aspirant
I don't see any erros in those logs. The readycloud.log had hundreds of errors, but not sure if that is linked to the slowness? I don't need access to the cloud as much as i need my local network to be functional and fast. Thank you so much for taking the time to help me out, i'm a little bit of a noob when it comes to the NAS.
- StephenBFeb 19, 2019Guru - Experienced User
You could try temporarily disabling ReadyCloud and see if that solves the performance issue.
- GilfammedicineFeb 25, 2019Aspirant
So just running through some of the more obvious issues that could be causing my slow speeds, i switched out the Cat 5e to a Cat 6 and these were the speeds i got. The ones before were going as low as 10mb/s. So hopefully i had a faulty cable. I will continue to runs the speed test and see what i am getting on the new cable.
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on O: 5 times...
Iteration 1: 103.92 MB/sec
Iteration 2: 101.55 MB/sec
Iteration 3: 109.74 MB/sec
Iteration 4: 106.92 MB/sec
Iteration 5: 95.01 MB/sec
Average (W): 103.43 MB/sec
Running a 400MB file read on O: 5 times...
Iteration 1: 48.33 MB/sec
Iteration 2: 94.97 MB/sec
Iteration 3: 60.59 MB/sec
Iteration 4: 94.03 MB/sec
Iteration 5: 98.15 MB/sec
Average (R): 79.21 MB/sec
Running warmup...
Iteration 1: 98.70 MB/sec
Iteration 2: 63.76 MB/sec
Iteration 3: 81.34 MB/sec
Iteration 4: 86.08 MB/sec
Iteration 5: 91.80 MB/sec
Average (W): 84.34 MB/sec
Iteration 1: 96.74 MB/sec
Iteration 2: 87.21 MB/sec
Iteration 3: 70.43 MB/sec
Iteration 4: 107.70 MB/sec
Iteration 5: 104.57 MB/sec
Average (R): 93.33 MB/sec
