Gilfammedicine
Feb 13, 2019Aspirant
How do i do a Speed Test?
My ReadyNas 212 is running extremely slow. Last time i just did the update and it solved the problem. But this time there is no update. My Antivirus is off and it has been working very fast recently....
- Feb 14, 2019
If you have a Windows PC, I suggest using NAStester ( http://www.808.dk/?code-csharp-nas-performance )
Feb 19, 2019Guru - Experienced User
You could try temporarily disabling ReadyCloud and see if that solves the performance issue.
Gilfammedicine
Feb 25, 2019Aspirant
So just running through some of the more obvious issues that could be causing my slow speeds, i switched out the Cat 5e to a Cat 6 and these were the speeds i got. The ones before were going as low as 10mb/s. So hopefully i had a faulty cable. I will continue to runs the speed test and see what i am getting on the new cable.
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 400MB file write on O: 5 times...
Iteration 1: 103.92 MB/sec
Iteration 2: 101.55 MB/sec
Iteration 3: 109.74 MB/sec
Iteration 4: 106.92 MB/sec
Iteration 5: 95.01 MB/sec
Average (W): 103.43 MB/sec
Running a 400MB file read on O: 5 times...
Iteration 1: 48.33 MB/sec
Iteration 2: 94.97 MB/sec
Iteration 3: 60.59 MB/sec
Iteration 4: 94.03 MB/sec
Iteration 5: 98.15 MB/sec
Average (R): 79.21 MB/sec
Running warmup...
Iteration 1: 98.70 MB/sec
Iteration 2: 63.76 MB/sec
Iteration 3: 81.34 MB/sec
Iteration 4: 86.08 MB/sec
Iteration 5: 91.80 MB/sec
Average (W): 84.34 MB/sec
Iteration 1: 96.74 MB/sec
Iteration 2: 87.21 MB/sec
Iteration 3: 70.43 MB/sec
Iteration 4: 107.70 MB/sec
Iteration 5: 104.57 MB/sec
Average (R): 93.33 MB/sec
