TonVH1
Oct 27, 2012Aspirant
How to access Frontview from remote?
I expected that "https://MyIP:443" would get me to the Frontview. (MyIP being the IP-adress and router forwarding 443). Alas, it does not. I am asked to enter ID/PsW (use the Admin as UID and corre...
mdgm-ntgr
Oct 27, 2012NETGEAR Employee Retired
You need to go to https://MyIP/admin to access Frontview
By default https://MyIP would redirect to https access to shares you've enabled access to over that protocol under Shares > Share Listing in Frontview. Though you can change that to point to a different share. For security reasons it's good that things work this way when exposing the NAS to the internet as it's that little bit harder for an attacker to find the admin section and attempt to break in. Do make sure you have a strong password set for the admin user.
Edit: beaten.
Edit: beaten.
