luckyinpa
Nov 03, 2019Aspirant
how to attach NAS to sound bar for movies?
readynas 422 if i put movies on the readynas they are easy to stream to my sony tv. however id love to pipe the sound to my sound bar. right now my tivo HDMI goes to the soundbar then hdmi fr...
schumaku
Nov 03, 2019Guru - Experienced User
Simple: You can't do this on the NAS. The audio signal has to come from the TV to the soundbar. This is done by HDMI ARC (Audio Return Channel if TV and soundbar does support it. Alternate approach is using a optical TOSlink from the TV to the soundbar.
Nov 04, 2019Guru - Experienced User
Of course if you are using a receiver or media player, the cabling could connect to those devices (not directly to the TV).
But as schumaku says, not from the NAS - it is just streaming over it's ethernet connection.
