ChristopheD
Dec 10, 2015Aspirant
How to downgrade firmware from 6.4.0 to 6.2.5 on RN104? Please help!
Well, I think it is best to not describe the disappointment of FW 6.4.1. Had to revert back to 6.4.0 in a hurry. But that does not fix the back up issues. Everything was running fine in 6.2.5 and I ...
- Dec 10, 2015
Like so many many many many... other people, I did the upgrade to 6.4.0 a while ago, then had a few lock ups, then lots of lock ups, then total lock up where I had to boot into read only mode, then the excitement of finding 6.4.1, then more lockups, until I really had no choice but to downgrade to 6.2.5.
After reading many many many posts and wasting many many many hours, I used the instructions from ifixdevices as a guide to reset both my RN104s back to 6.2.5.
Specifically, I copied everything off (many many many hours).
Downloaded 6.2.5 and prepped a jumpdrive.
Power down NAS (at this point that was unplugging it :) ) insert the jumpdrive.
Power up while holding Backup button, release once "Booting from USB" is displayed, wait for it to power down.
Find the hidden Reset button, boot into Factory default mode.
At this point I was back at 6.2.5 for both units and just have to wait through one more resyncing...(many many many hours)
Slowly copying everything back and so far no issues.
Thankfully my RN102 wouldn't install 6.4.0 or I'd still have one more to do.
Charge
ChristopheD
Charge: thank you very much for your response, it was very clear. I certainly appreciate the help.
Question : if I back up my configuration, could I then, after the factory reset, restore the configuration (ie, shares, users, etc...) or am I hooped?
- ChargeDec 10, 2015Aspirant
You're welcome.
I haven't used the backup config function so can't say for sure, but if you have a good 6.2.5 backup seems worth a try.
