MSR1
Feb 20, 2012Follower
How to enable a trash folder on ReadyNAS Duo 2
I want to be able to set up a Trash bin on the ReadyNAS Duo that functions similarly to the Windows Recycle Bin (deleted items go into the bin until the trash is emptied). Although I've read posts on...
mdgm-ntgr
Feb 20, 2012NETGEAR Employee Retired
If you are comfortable with SSH (use of this is unsupported) then you can enable this for CIFS (i.e. Windows file sharing). I discussed this recently in this thread: http://www.readynas.com/forum/viewtopic.php?p=342388#p342388. The Recycle Bin will only work over CIFS, not other protocols. There are no options for this in the new Dashboard UI found on the Duo v2, with the current firmware in RAIDiator 5.3.3. Hopefully they add this feature in a future firmware update.
Also RAIDiator (OS/firmware on the NAS) is very different to RAIDar (client software your run on your PC/Mac/Linux machine).
