MSR1
Feb 20, 2012Follower
How to enable a trash folder on ReadyNAS Duo 2
I want to be able to set up a Trash bin on the ReadyNAS Duo that functions similarly to the Windows Recycle Bin (deleted items go into the bin until the trash is emptied). Although I've read posts on...
NASNoob11
Feb 23, 2012Aspirant
Can I raise a question about the Recycle Bin logic of the DUO-v1?
I use this feature. I do understand the Time/Days metric. Please explain the File Size metric! I am clueless as to how to use this setting.
I do accept that the DUO does its' best to clean out the Recycle Bin via the setting I choose. Do these settings 'assume' that my DUO runs 24/7 hot?
I allow my drives to go to sleep after 2 hrs of inactivity. I suspect this 'nap' feature kinda-sorta interrupts my chosen Recycle Bin logic. Is this correct?
I do see that the Recycle Bin is eventually cleansed; but, mostly many days/weeks later............. :D
