MSR1
Feb 20, 2012Follower
How to enable a trash folder on ReadyNAS Duo 2
I want to be able to set up a Trash bin on the ReadyNAS Duo that functions similarly to the Windows Recycle Bin (deleted items go into the bin until the trash is emptied). Although I've read posts on...
mdgm-ntgr
Feb 24, 2012NETGEAR Employee Retired
The Limit recycle bin to is the total space that can be filled by it. So if set to 10GB if the deleted files collectively exceed 10GB in size the NAS will take action.
Not sure whether it deletes everything in the recycle bin or not. I don't use this feature and can't remember checking this.
