MSR1
Feb 21, 2012Follower
How to enable a trash folder on ReadyNAS Duo 2
I want to be able to set up a Trash bin on the ReadyNAS Duo that functions similarly to the Windows Recycle Bin (deleted items go into the bin until the trash is emptied). Although I've read posts on this functionality elsewhere in this form the information provided is years old and doesn't seem to apply to the current version of RAIDar 5.3.3.
At least I've been unable to locate the settings referred to in those posts, for instance I cannot find an recycle bin, nor does a path like "Share Name / Description / Password / Disk Used / Quota (MB) / CIFS / NFS / FTP/S / HTTP/S / Rsync / Delete" make sense to me.
Can anyone tell me where to find the settings to enable/disable a Trash/Recycle Bin functionality for ReadyNAS shares using RAIDar 5.3.3? And if so, can you advise if the setting for the entire drive or just for an individual share?
- mdgm-ntgrNETGEAR Employee Retiredtaylord01, not really relevant to this thread as you have a Duo v1, but the Recycle Bin only works over CIFS (e.g. \\ip.address.of.nas or \\hostname). Is that what you're using? If not that would explain why the files don't appear in the Recycle Bin folder after deletion.
