jumjum
Mar 18, 2013Follower
How to Power of Readynas NVX with iPhone/iPad
Hi, I want to switch on and switch off my readynas NVX when i'm at home with my iPhone. Whitout walking to the ceiling. With a PC it's easy Wake on Lan to switch on and off with Curl from http...
mangrove
Mar 31, 2013Apprentice
Just go to the shutdown url directly. I use WGET on a PC but you could use your app, probably. The URL will look something like this:
https://ip_address_of_your_nas/get_handler?PAGE=System&OUTER_TAB=tab_shutdown&INNER_TAB=NONE&shutdown_option1=1&command=poweroff&OPERATION=set
You will also have to feed it your login credentials.
You might have to muck around in the HTML in Frontview to get another URL, dunno if the ARM devices have the same file names/structure in their Raidiator.
