armornone
Oct 30, 2012Aspirant
How to setup UPS backup on 5 Readynas systems via usb cable?
I have 5 Readynas X6/600 units and a single APC UPS backup for all of them and extremely unreliable power from the power company. I was wondering if I could setup the UPS to connect with a USB cable t...
armornone
mdgm wrote: No you can't share the UPS that way. However you can share the UPS. You need to connect the power cable for your router/switch to the UPS as well and share the UPS from one NAS over your network to the other units.
You need to configure settings under System > Power > UPS on each NAS unit, both to share the UPS from the NAS the UPS is connected to via USB (power cable from the NAS also needs to be connected to UPS of course) and to connect to it from the other units.
If you want PCs to share the UPS as well there's even a guide on Using the ReadyNAS to create a Network UPS for PCs
So the Readynas # 2, #3, #4, #5 can all monitor the USB connection on the UPS connected on Readynas #1 unit and shutdown in there is a power outage.
I see it asking for an IP address.
" Enable monitoring of UPS physically attached to a remote ReadyNAS
Remote IP address: xxx-xxx-x-xxx
If that is the case, my hat is off to the engineers who design this unit. This is very smart thinking.
