armornone
Oct 30, 2012Aspirant
How to setup UPS backup on 5 Readynas systems via usb cable?
I have 5 Readynas X6/600 units and a single APC UPS backup for all of them and extremely unreliable power from the power company. I was wondering if I could setup the UPS to connect with a USB cable t...
armornone
mdgm wrote: Yes. It's a feature of NUT (Network UPS Tools) which is used by the ReadyNAS (you can see it in the GPL or you could see the Config in a System > Config Backup)
Of course you need a working ethernet connection, a UPS that is compatible with the ReadyNAS and the UPS must be able to handle the load of all the devices
I am curious, is NUT(Network UPS tools) a 3rd party application that has been installed as a service within readynas or is this something that Infrant created on its own.
In any event, the readynas is so much more advance than my terastation live which is my other RAID system.
Thanks.
