Janti
Oct 16, 2011Aspirant
Impossible to Setup SqueezeCenter etc.
Hello all I'm new to this board and just installed (or tried to install) The ReadyNAS Duo. Lots of problems, but I wil mention one of them: Why Don't I succed to setup SqueezeCenter? Under Se...
markwoll
Oct 23, 2011Guide
If you have the squeeze center checked in streaming services it is enabled.
Open a browser window to {ip address of readynas duo}:9000 ( i.e. 192.168.0.2:9000 ).
This will bring up the setup screen for the Squeezebox Server. You will be asked for you username and password for mysqueezebox.com and the location of your music files on the readynas duo.
After you have entered this info the squeezebox server main page will come up, and the squeezebox server will begin to scan your music library.
Depending upon which squeeze box music players you have , Duet, Boom, Radio, etc you may need to upgrade your server software.
The upgrade instructions for readynas can be found here:
http://wiki.slimdevices.com/index.php/S ... n_ReadyNAS
If you have already upgraded your firmware to the latest version, skip those steps.
I have had good luck with the 7.6.1 software. Some other people have not. Sometimes non english characters cause problems with the library scanning portion of the product.
mark
mark
