Janti
Oct 16, 2011Aspirant
Impossible to Setup SqueezeCenter etc.
Hello all I'm new to this board and just installed (or tried to install) The ReadyNAS Duo. Lots of problems, but I wil mention one of them: Why Don't I succed to setup SqueezeCenter? Under Se...
Singularity
Oct 23, 2011Tutor
I had a few problems with 7.6.1. There is now a 7.6.2 version available and also a 7.7. I have installed the 7.7 because I required the SqueezeBox Server to access more than one folder. I have split my music into separate folders such as LossLess and MP3 etc.
Provided you have setup the SqueezeBox Server correctly on your NAS and that you have configured your Squeezeboxes correctly it should work perfectly. There are also a few rather good iPhone, iPad and Android Apps available which make the whole SqueezeBox experience very enjoyable.
I made great use of Genre iTags etc to make my system more manageable and easier to locate my music. Equally PLayLists can be used etc...
Now I guess my CD's are redundant....
