Janti
Oct 16, 2011Aspirant
Impossible to Setup SqueezeCenter etc.
Hello all I'm new to this board and just installed (or tried to install) The ReadyNAS Duo. Lots of problems, but I wil mention one of them: Why Don't I succed to setup SqueezeCenter? Under Se...
Janti
Oct 25, 2011Aspirant
bkv wrote: Hi
I believe I had to install the Squeezecenter add on first. Go to Add-ons->Add new and use the linl http://www.readynas.com/addons
Bjørn
Hello Bjørn (or anybody else)!
Where do I find these Go to Add-ons and Add new? On the Frontview? I don't find it there.
I find add-ons here:
http://www.readynas.com/?cat=36
And it says:
"Description: Update your SqueezeCenter on your ReadyNAS with the full version provided by Logitech."
Thus it seems it should already be installed.
Anyway. I cannot find it or enable it. I may tick off Enable in the Frontview and press Apply, but the next time i come to that page, it's not ticked off anymore.
Besides: What does the following mean:
There are two variants - the Pro/NX and the NV/NV+/Duo. Make sure to select the correct version for your ReadyNAS
CleanSqueezeCenter for sparc (NV, NV+, and Duo models) - http://www.readynas.com/?page_id=617
(Found here: http://wiki.slimdevices.com/index.php/S ... n_ReadyNAS)
How do I find out which of these variants I should install if any? As far as I know I have a regular ReadyNAS Duo, I don't know what Pro, NX etc. means.
Or is the only file or add-on I nead the one called CleanSqueezeCenter for x86 (Pro and NVX models) - found here: http://www.readynas.com/download/addons ... .0-x86.bin ?
Sorry for what might be considered stupid questions, but the fact is that none of my friends understand this either. None of us are programmers, but we are not too stupid either (I believe).
Best regards
Jan
