Janti
Oct 16, 2011Aspirant
Impossible to Setup SqueezeCenter etc.
Hello all I'm new to this board and just installed (or tried to install) The ReadyNAS Duo. Lots of problems, but I wil mention one of them: Why Don't I succed to setup SqueezeCenter? Under Se...
Singularity
Oct 25, 2011Tutor
You install a Add-On within FrontView.
On the FrontView menu select system/update/local then choose the binary file you want to install. Once the file is installed you can check the box to activate it.
To get the latest version of the SqueezeBox server for your NAS go to the Logitech site and download the required binary file. This is the file you need to install as detailed above.
There are two variants of the Netgear Nas. The Duo is the spark based and you need to ensure that you download the correct binary file for this model. The Pro is a x86 processor model and is aimed at serious home or business users.
After installation of the SqueezeBob Server on your Nas you will need to configure your SqueezeBoxes.
