HenrikR
Jan 26, 2014Aspirant
Installing RN314 - Device not detected
I just bought a Netgear ReadyNAS 314 and four WD Red 3.5 drives to put in it. I'm having some basic, probably very easy to resolve issues, but the manual (both physical and online) is extremely unhelp...
vandermerwe
Jan 26, 2014Master
Removing the gateway will not help.
Was the gateway connected properly? Is it possible you had the NAS connected to the WAN port instead of a lan port?
Is this the internet connection you have been using to access the forums?
There is a WAN port to connect to your fibre connection, then 4 lan ports, 1 should connect to your NAS, 1 to your PC.
Connect to the gateway at 192.168.1.1.( from your PC) This is the default IP address given in the manual I found, it may be different(192.168.2.1), check your manual ( for the VoIP gateway)
The default login details for your VoIP gateway are username admin, password admin.
Log in to the gateway and look at the dhcp server.
