HenrikR
Jan 26, 2014Aspirant
Installing RN314 - Device not detected
I just bought a Netgear ReadyNAS 314 and four WD Red 3.5 drives to put in it. I'm having some basic, probably very easy to resolve issues, but the manual (both physical and online) is extremely unhelp...
vandermerwe
Jan 27, 2014Master
Yes. OP seemed to have set up the unit from scratch therefore I'd assume it was set to dhcp, however it's not behaving that way now.
He had it connected to this gateway which he cannot access, although I can't see how an incorect connection would lead to a permanent change in the settings.
Hopefully an OS reinstall will reset it to dhcp and he'll be able to access it.
Otherwise I think I've run out of suggestions, short of pointing to support.
HenrikR, the other thing you could try is removing the inteno gateway from the lan ( temporarily). Disconnect it from the belkin so that it is not available to the NAS.
Please post results of this and/ or your OS reinstall.
