benrhughes
Oct 26, 2014Aspirant
Is it possible to downgrade to 4.1.13?
Since the 4.1.14 upgrade, my NV+ hasn't been it's usual bulletproof self. It seems to get completely bogged down on occasion - eg ssh tunneling - and tonight I had to hard reboot it for the first time...
benrhughes
Thanks. My OS partition is ok (thanks to mdgm fixing it up after the 4.1.14 upgrade went awry for that very reason). I'm torn between downgrading, waiting for for the next patch, and clean installing. The standout feature of the NV+ over a home rolled solution is almost literally never having to worry about it for the ~4 years it's been running. Having it being a bit flaky is a weird and disconcerting experience.
