StuBarrett1
Sep 24, 2015Aspirant
Is my ReadyNas Pro running too hot?
Upgraded my disks and they appear to be running pretty hot. Ambient temp is around 78F. If this is too hot, what can I do to help? Thanks, Stu Device Description ...
- Sep 24, 2015
StuBarrett1 wrote:
BTW, yes, I have cleaned the dust :-)
The above temps were with the side panels off, after putting them back on, the temps are lower, but I'm wondering if still too high?
I think they are ok (after all the datasheet does say 5-60C operating range). Lower temps might be better, but I wouldn't void the warranty or do anything heroic to get them.
Sep 24, 2015Guru - Experienced User
itsjasper
Sep 25, 2015Luminary
Hitachi drives do tend to run slightly higher temps. Yours look similar to my Hitachi numbers at 40-42 °C. I've had mine installed in the NAS for 3 years without issue.
And without the sides fitted to direct airflow correctly throught the unit, the drive temperature will be higher, unless you are pointing a desk fan directly at them... :-)
