mlight
Dec 03, 2015Aspirant
Issue with ReadyNas NV+ after changing a drive
Yesterday I swapped out the 4th drive in my ReadyNas NV+. I got a number of emails from the NAS.
- Disk remove event occurred on SATA channel 4.
- Disk fail event occurred on SATA channel 4.
- A SATA reset has been performed on one or more of your disks that may have affected the RAID parity integrity. It is recommended that you perform a RAID volume resync from the RAID Settings tab ( accessible in the Volumes page => Volume tab in FrontView ). The resync process will run in the background, and you can continue to use the ReadyNAS in the meantime.
- Disk add event occurred on SATA channel 4.
- Disk initialization started. The estimated time of completion is 17 hour(s) and 39 minute(s), at which time you will be notified via email. You can also check the progress in Frontview in the Volumes -> RAID Settings tab. Please do not shutdown the system while the initialization is in progress.
Sometime after that last email I noticed that the NAS was unreachable. I wasn't sure about the time, but it was probably under an hour. I couldn't ping it or use the Raidair app to connect to it.
There wasn't a message on the front panel, it just had the IP address and the size info. So I just let the NAS blink away, waiting for when it would be finished.
And that last email was yesterday more than 24 hours ago.
This was the 4th drive that I swapped out. I had to swap out Drive 2 due to a sudden failure. I had been receiving occassional SMART error emails on Drive 3, but nothing on Drive 2. I swapped out Drive 2. It initialized successfully and it synced successfully. That was in April of this year. When Drive 3 went past the 30 mark on SMART errors, I swapped that out too. That was at the end of September of this year. A few days ago on the 1st of December, I swapped out Drive 1 and that went well.
So I am having trouble with Drive 4 now. All of the drives are WD 2GB Reds.
Any suggestions?
Thanks.
The drives have a 3 year warranty, are they still covered?
In terms of how to proceed - I'd power down the NAS and test all the drives with WDC's lifeguard program in a PC. Label by slot of course.
You can also try booting the system w/o drive 4 (power down before you remove it).
Do you have a backup of the data?
- JennCNETGEAR Employee Retired
Hello mlight,
Please download the logs.
Can you also please check what you get under Volumes > Volume Settings? Post a screenshot if possible.
- mlightAspirant
I can't get to the readyNas NV+ to get the logs.
I haven't shut it down yet.
The othere 3 drives are fine. I just picked up this drive last week, so I can return it there.
