tcatech
Sep 26, 2014Aspirant
Issues with Ready NAS 314, destination is read-only
Issues with Ready NAS 314, destination is read-only.
Firmware 6.1.9
Seagate 4TB USB 3.0 HDD ST4000DM
NAS set up with 3 shares (Tech, Manager and Marketing). Our marketing department has 5 users that share this NAS and they all connect to these shares thru afp.
We recently purchased a Seagate USB HDD to back up the files on the NAS once per week.
I have 3 backup jobs running 2 on Saturday and one on Sunday. The 2 jobs that run on Sat are smaller and are for the tech and manager shares). These backup jobs run with no problem. The backup job for the marketing Share is the largest of the 3 shares and takes about 55 minutes to backup. The Issue I am having is that the backup logs tell me the backup failed destination is read only. Although it appears that the files copied successfully. Don’t really know a way to compare what is in the NAS and what is on the external HDD to see if everything copied. It appears that everything copied. But I still get the FAIL in the log.
See below for a copy of the Backup Log!
Backup Job Name: Marketing Weekly BAK
Backup Job Type: Incremental
Protocol: local
Backup Source: [Marketing]/
Backup Destination: [USB_HDD_4]/Marketing
Backup Start Time: Thu Sep 25 2014 17:03:40
Backup Finish Time: Thu Sep 25 2014 18:03:41
Backup Status: Fail: destination is read-only.
Any Suggestions?
Firmware 6.1.9
Protocol: local
Any Suggestions?
- mdgm-ntgrNETGEAR Employee RetiredWhat filesystem is on the USB disk?
If you download the logs, what is the date in bios_ver.log ? - tcatechAspirant
mdgm wrote: What filesystem is on the USB disk?
NTFS
bios_date=04/03/2013
bios_vendor=American Megatrends Inc.
bios_version=4.6.5 - mdgm-ntgrNETGEAR Employee RetiredIs the SeaGate disk set to automatically spin down? If you turn that spin down feature off does it make any difference?
- tcatechAspirant
mdgm wrote: Is the SeaGate disk set to automatically spin down? If you turn that spin down feature off does it make any difference?
Where is the option to make the Segate disk "Spin Down"?
Is that the Auto eject device when the job is done? (If that is under destination tab of the backup? This is unchecked. ) - mdgm-ntgrNETGEAR Employee RetiredIt might be set using a SeaGate tool you could run when the disk is connected to a PC.
- tcatechAspirant
mdgm wrote: It might be set using a SeaGate tool you could run when the disk is connected to a PC.
Thanks,
I will check into this and get back to you. - tcatechAspirant
tcatech wrote: mdgm wrote: It might be set using a SeaGate tool you could run when the disk is connected to a PC.
Thanks,
Well I found the SeaGate USB Drive is not set to spin down. So I still am at a loss for a resolution of this and my other issues with this NAS. - vandermerweMasterHave you tried reformatting the backup disk and running the backups again.
Can you consider using a different format to ntfs like ext4?
Also try running a disk check on the USB disk. - mike_nycomAspirantunplug the USB hard drive and plug it into a PC, it should say the hard drive needs to be scanned to continue doo this and let it complete, then plug it back in the NAS.
A bit like win98 you have to eject the USB hard drives before removing them otherwise the data becomes read only until it has had a check disk - XAffiAspirantHi all,
I have a similar/same issue with my RN104. I made my Backup on an external WD 1TB 3,5" hard drive (USB2). It works well for all shares except one. It tells me that the destiination is read only. I assume the backup is finished, because it occures at the end (just my assumption). I am not sure if the external drive is meant be "destination". However --- It says backup is fail. Any idea how to figure out where it comes from?
BTW: I checked the harddrive on my local WIN machine, without any error.
Checking the logs in /var/log/frontview/backup:
status_backup_009:
BACKUP_STATUS__FAILED!!1415532530!!warn
and backup_009_copy.1415532530.log does not look different than for the other shares... It contains only one "interesting" line : "BACKUP_INFO_LOG_TRUNCATED:257630". But this seems nothing critical. Any additional ideas?
Thanks in advance.
Norbert
BTW: I got snmp data errors while the USB bcakup is running.. Is this usual?
